Hydraulic fluid leak
cswiger
Postby cswiger » Wed Oct 14, 2020 8:31 am
I have been a long time follower of the forum and have learned a great deal from the other participants. I have a question for the forum now and would greatly appreciate any help you can give me. I have a 2310D that has recently started to leak hydraulic fluid at an alarming rate. After cleaning the area I started the tractor and looked for the source of the leak. What I have found is a round plastic plug on the right side of the transmission that is a push in cover of some sort. It doesn't appear to have a gasket or o-ring of any kind of seal. When I removed the plug I can see inside the transmission. When the tractor is running the cover rotates freely and fluid burps out around it. I have no idea what I'm looking at or for. Any help or suggestions would be fantastic. I will try to attach a picture of the area. Thanks.
Yanmar Hydraulic Leak (2).jpg (216.08 KiB) Viewed 101 times
Re: Hydraulic fluid leak
Postby Aaron » Wed Oct 14, 2020 9:21 am
That is your bellhousing and it should be dry in there. If you have transmission oil in there then either the powershift pump seal or one of the transmission gaskets in there is leaking.
https://www.hoyetractor.com/ClutchVideo.htm
Users browsing this forum: No registered users and 52 guests
