3 point hitch stuck up
Jdup
Postby Jdup » Sun Oct 04, 2020 11:06 am
3 point hitch stuck up , I have tried push down by hand and there’s a grinding noise coming from rear. It too much pressure is allied motor dies .
Re: 3 point hitch stuck up
Postby winston » Mon Oct 05, 2020 10:53 am
Sounds like lift piston is stuck in cylinder. Might try a heavy hammer on lift arms, not hard enough to break something.
Supposing the grinding noise is a separate problem than the lift?? Does it do this when moving or just when does it?
I don't understand "It too much pressure is allied motor dies". :?
Users browsing this forum: No registered users and 21 guests
