YM 140 leak
chip
YM 140 leak
Postby chip » Tue Sep 29, 2020 5:17 pm
I have a YM140, 4wd that has developed a leak at the input shaft of the transmission. After removing the assebly, it appears to be a gear pump. there is a bushing of sort over the splined shaft that rides inside the seal. Was wondering if anyone had part numbers or a place to get new parts from?
Re: YM 140 leak
Postby winston » Wed Sep 30, 2020 9:22 am
Looks like the 140 is a geared transmission. If that is correct I can't imagine a pump being inside the transmission. Would think this would be the splined coupling. https://www.hoyetractor.com/PROD/SC-2618.htm
I'm sure Hoye could identify the seal.
Re: YM 140 leak
Postby Aaron » Wed Sep 30, 2020 2:43 pm
Are you sure it is a 140 and not a 147?
chip
Re: YM 140 leak
Postby chip » Fri Oct 02, 2020 3:43 pm
I'm not sure it's a 140. That's just what the hood says. But the diagram for the power shift pump looks correct
chip
Re: YM 140 leak
Postby chip » Fri Oct 02, 2020 3:47 pm
It looks like part b and 12. Not sure if 4 and 10 are o rings or snap rings. Can only find 1 snap ring on the shaft
Users browsing this forum: No registered users and 51 guests
