Hydraulic joystick replacement?
wildbitshomestead
Postby wildbitshomestead » Fri Sep 18, 2020 11:34 pm
The hydraulic joystick on my 2002d has come loose. Have to fiddle with it to get it to stick into the nut to move the FEL.
I’ve taken it apart to see what the issue is and it seems the thread of the joystick doesn’t match up with the nut in the (gearbox?) it’s too small and is a huge pain in the butt. First it would work with some finagling, but today I can only get it to move the fel up and down, won’t move side to side to tip it.
I’ve looked on Hoye for a replacement but no luck.
Anyone know where I can get a replacement that will fit correctly?
Re: Hydraulic joystick replacement?
Postby winston » Sat Sep 19, 2020 4:55 am
Threads must be bad on handle, nut or both. Can you determine which?? Do you know the manufacturer of the valve and maybe model number?
Users browsing this forum: No registered users and 57 guests
