Tractor won’t do anything
AllenB
Postby AllenB » Thu Sep 17, 2020 9:05 am
I just picked up a Yanmar FX32D yesterday, ran it for an hour, shut if off and now nothing will turn on. I can turn key but gauges don’t come on and no clicking of starter.
Re: Tractor won’t do anything
Postby Aaron » Fri Sep 18, 2020 12:20 pm
Sounds like a bad battery connection. Also check where the ground wire from the battery bolts to the frame.
wildbitshomestead
Postby wildbitshomestead » Fri Sep 18, 2020 11:08 pm
I had this happen to me on my YM2002D and it turned out that it was the clutch wires had just come loose. Not sure if yours is the same, but on mine it was under the clutch pedal, I just had to push them back together, vibration caused them to come undone. Have had to do it a few times, keep meaning to wrap it with electrical tape so it stays put.
Users browsing this forum: No registered users and 42 guests
