ym 1500 questions on fluid type and capacity
macmov
Postby macmov » Sun Sep 13, 2020 3:52 pm
I am very confused and can't seem to zero down on a definitive answer. I drained the gearbox transmission now I am not sure if it takes Universal Tractor Trans/Hydraulic or type or 90w-140 gear oil.
Also while I was down there, I realized there was another drain plug just to the rear of the transmission drain that I thought was the PTO, now I am not sure if that is actually part of the pto or the Hydraulics or both. The what oil to use in this case and to what level because I see no dip stick. Please help, at this point I don't want to move the tractor in fear of contaminating the system. :oops:
Re: ym 1500 questions on fluid type and capacity
Postby Aaron » Mon Sep 14, 2020 9:10 am
It is one big reservoir that uses transmission/hydraulic oil. See link below
viewtopic.php?f=2&t=580
Users browsing this forum: No registered users and 39 guests
