John Deere 750 Tractor PTO Clutch Assembly
JD750
Postby JD750 » Fri Sep 04, 2020 12:10 pm
Can someone help me find a PTO Clutch assembly for my 1983 John Deere 750 Tractor. The John Deere part number is LVA801788 and John Deere says this part is obsolete and is no longer available. If this part cannot be found, does anyone know where can I get mine rebuilt? Thanks
Re: John Deere 750 Tractor PTO Clutch Assembly
Postby Aaron » Fri Sep 04, 2020 1:19 pm
That clutch looks different than the clutches used on the Yanmars (which are also no longer available).
I believe they may have been made by Ogura if that helps.
Postby winston » Fri Sep 04, 2020 5:11 pm
JD750
Postby JD750 » Sat Sep 05, 2020 11:29 am
Thanks Aaron for your info and Winston for your help. I looked at the one on ebay and says it is 'sold as is" without knowing if it works or not.
Postby winston » Sat Sep 05, 2020 6:17 pm
Might try contacting the guy and see if he would be willing to test it.
JD750
Postby JD750 » Mon Sep 14, 2020 1:37 pm
Aaron,
I contacted Ogura and Jim Andes Application Engineer Ogura Industrial 100 Randolph Road Somerset, NJ 08875 732-271-7310 Fax 732-271-7580
jandes@ogura-clutch.com
http://www.ogura-clutch.com, says he cannot find the John Deere part numbers CH15320 or LVA801788 for a John Deere 750 tractor, he said their JD parts start with "AM" or "TCA". Do you have any way to cross reference the John Deere numbers to a Ogura part number?
Thank you for all of your help,
Jim Goostree
270-223-0306
Postby Aaron » Tue Sep 15, 2020 11:37 am
If a part is no longer available from John Deere then any Deere dealer can give you the original manufacturer's part number. They all have access to that database. That is what you would need.
Users browsing this forum: Google [Bot] and 49 guests
