Yanmar 1500d steering components
Ryanap123
Postby Ryanap123 » Mon Aug 31, 2020 8:01 am
On the left front of the tractor, there is the case directly behind the tire with gears and a splined shaft protruding on top. Here one of the steering components attaches. It is also here that a previous owner had welded the two parts together. This appears to have happened after the splines stripped and the tractor could no longer steer. Well the weld has broken and id like to replace the parts. What parts do i need and how is this accomplished?
Re: Yanmar 1500d steering components
Postby Aaron » Mon Aug 31, 2020 12:54 pm
Do you have the 'red' or 'green' style? See link below
https://www.hoyetractor.com/indeximages ... OR-RED.jpg
Postby winston » Mon Aug 31, 2020 1:38 pm
Users browsing this forum: No registered users and 41 guests
