Milky hydraulic fluid
frogeye100
Postby frogeye100 » Sun Aug 30, 2020 8:42 am
Hi there,
6 months ago I changed the hyd fluid in my ym336d because the hyd fluid had become contaminated with water. It has happened again, and I can't find how rain could be getting in. Shift boot looks good, any other areas to inspect?
Unfortunately it sits out in the weather. I'm going to tarp it after another fluid change.
Dean
Re: Milky hydraulic fluid
Postby winston » Sun Aug 30, 2020 1:06 pm
Dip stick have a gasket under it? U shaped vent on top the rock shaft not broken off?
frogeye100
Postby frogeye100 » Thu Sep 03, 2020 1:04 am
Dipstick gasket looks ok, where is the U shaped vent?
Thank you,
Postby winston » Thu Sep 03, 2020 5:32 am
#5 on the drawing.
frogeye100
Postby frogeye100 » Thu Sep 03, 2020 3:56 pm
Got it, thank you. The breathers look fine. Gonna change the hyd fluid again and diligently tarp it when not in use.
Users browsing this forum: taty and 29 guests
