O ring between 3ptvalve and lift
McPhly
Postby McPhly » Sat Aug 29, 2020 5:28 pm
In the last 50 hours of brush hogging I've had to replace this O ring two times. Each time the 3pt valve was removed the O ring was broken and some of it missing. Any ideas or suggestions will be welcome.
Re: O ring between 3ptvalve and lift
Postby Aaron » Mon Aug 31, 2020 12:53 pm
There have been a couple posts in the last year about that. It usually comes down to buying a metric o-ring locally that is not quite correct.
See below.
viewtopic.php?f=1&t=9897&p=36109#p36109
viewtopic.php?f=1&t=10063&p=36758&hilit=oring#p36758
Users browsing this forum: No registered users and 52 guests
