Shifting issue's
Just-speed
Re: Shifting issue's
Postby Just-speed » Tue Sep 08, 2020 7:49 am
Unfortunately yesterday while using tractor suddenly ended up doing again exactly the same thing that had me find the spring broken. Back to long delay and only at high rpm. Can't believe this. Now I'll have to take apart again and hope I see something wrong
Postby winston » Tue Sep 08, 2020 10:26 am
Wow, if spring is broken I would consider the possibility of over pressuring.
Just-speed
Postby Just-speed » Wed Sep 09, 2020 5:41 am
Today when I get home I plan to inspect. So frustrating I had to ignore for a day. If spring is broken and that means over pressure how would I remedy that. If the spring isn't broken I'm not sure what I'll need to look at. Hopefully I see something obvious
Postby winston » Wed Sep 09, 2020 9:38 am
Looks like a wait and see what you find. The relief valves do have shims for adjustment but you need to take a good close look in section 250 in the manual trouble shooting section. Especially 250-10-23
Just-speed
Postby Just-speed » Wed Sep 09, 2020 2:09 pm
Took apart and found nothing more than before. Some parts have wear but there are no replacement parts listed anywhere.
I drained fluid hoping filter was dirty but no dice. Filter looks fantastic. I'm gonna check the spring lengths vs book requirements and if off I can perhaps massage the springs to correct length possibly.
I know one of the sleeves...actually both have signs of wear but as I search I really find no replacement parts except the springs and gasket
Postby winston » Wed Sep 09, 2020 2:24 pm
Might also consider checking pressure per manual.
Just-speed
Postby Just-speed » Wed Sep 09, 2020 2:29 pm
Agreed, however unfortunately being a lover of tools and having more than i need most times I do not have fitting or proper gauge to test with
Just-speed
Postby Just-speed » Wed Sep 09, 2020 3:36 pm
Pulled apart again. Checking spring length and outer spring is just a bit short. Unfortunately first pull on spring I did with my hands it broke. I'm so upset. Its Wednesday afternoon and if I order from Hoye now I'll likely not receive until next week. I hate paying $15 shipping on 3 stamp items and getting a week later
Just-speed
Postby Just-speed » Wed Sep 09, 2020 3:43 pm
I mentioned something about 3 stamp item and long shipping time. I log in to purchase and like magic there is a $7.95 option suddenly. Every order prior has only been $14.95 option. I love the better option. Spring is ordered. Maybe I'll get lucky and it was the issue. It wasn't broke before I broke it though.
Postby winston » Wed Sep 09, 2020 5:41 pm
Let's hope it was just on it's last leg.
Just-speed
Postby Just-speed » Wed Sep 09, 2020 7:09 pm
Thanks for being positive Winston. Hoping for the same thing. Unfortunate as these machines age parts become difficult to find. Reality is likely that I'll need to upgrade soon but hoping not to soon.
Just-speed
Postby Just-speed » Sun Sep 13, 2020 10:41 am
The outer spring arrived yesterday. Popped it in and shifting seems to have gone back to great. Almost no delay at all so I'm hoping I'm done with this issue and can just work the tractor. Also added water temp sensor. Glad to see holding 170f temp no problem.
Postby winston » Sun Sep 13, 2020 4:27 pm
Hope this is a "real" happy ending.
Users browsing this forum: Google [Bot] and 36 guests
