YM3000 1 & 3 Shift Fork
sarodude
Postby sarodude » Tue Aug 18, 2020 12:58 pm
Helping a friend with a YM3000. Among the gargantuan list of fustercluckery on this poor tractor from before his acquisition of it, it now sports a broken 1 & 3 shift fork. I've inspected things as much as I can by removing the tranny cover (where the shifter sits) and can confirm the break.
Additionally, if I manually slide the 1 / 3 shift shaft forward / backward, it gets stuck. Strangely, once it's unstuck, it moves ok reassembled with the shifter.
I'm unable to see how to replace the shift fork without disassembling the trans. Am I missing something? The shift shafts only slide forward / backward enough to affect gear changes. Seems that the pins must be driven from the forks and the shafts slid forward (where they're hitting some other piece of housing).
Help!
PS - While not new to vehicle work, I just barely learned to spell trakter.
Re: YM3000 1 & 3 Shift Fork
Postby Aaron » Thu Aug 20, 2020 10:35 am
I don't think there is any way to get those shafts out without splitting the tractor. Sometimes the little detent balls (23) get wore down or damaged and it will cause the rails to stick
sarodude
Postby sarodude » Thu Aug 20, 2020 12:15 pm
Thanks, Aaron. Kinda what I figured. I guess I was hoping for magic.
Users browsing this forum: No registered users and 55 guests
