1610d hyd. fel. problem
Richard Flurry
Postby Richard Flurry » Thu Aug 13, 2020 2:17 pm
1610d fel. must use 3point at different settings to get loader to raise or lower . does not have joystick. line from pump has tee for lift fluid then on to 3 point.
Re: 1610d hyd. fel. problem
Postby Aaron » Sat Aug 15, 2020 10:34 am
You can not use a tee with an open center hydraulic system (all Yanmars & most all other brands). You have to plumb the pressure side in series or use power beyond.
Postby winston » Sun Aug 16, 2020 4:11 am
Just a little more explanation how it should be unless you have power beyond. https://www.hoyetractor.com/loaderinstall.htm
Users browsing this forum: Bing [Bot] and 26 guests
