F14D electrical warning light
Beecrazy
Re: F14D electrical warning light
Postby Beecrazy » Thu Jul 30, 2020 3:19 pm
So, it’s looking like a faulty voltage regulator.
Postby winston » Thu Jul 30, 2020 5:27 pm
I think it may be faulty but am not sure that is what causing your light to stay on.
Beecrazy
Postby Beecrazy » Mon Aug 03, 2020 9:16 pm
I installed the new voltage regulator and the warning light is off. With the engine running I’m getting a voltage of 13.9. My assumption is that the warning light does come on for high voltages as well as low. As for the “normal range” of operation, it must be around 14 volts. This is based on the voltage readings after the light had gone out.
Thanks for the help.
Postby winston » Tue Aug 04, 2020 3:47 am
Glad to hear problem solved.
Users browsing this forum: No registered users and 33 guests
