Temperature sensor
GBuford4372
Temperature sensor
Postby GBuford4372 » Thu Jul 23, 2020 10:58 am
Can someone post a diagram or describe where the temperature sensor is on a ym2010. I think I found it on the side of the water pump? But want to make sure. And what is the operation temp of this engine? Ballpark?
GBuford4372
Re: Temperature sensor
Postby GBuford4372 » Thu Jul 23, 2020 2:31 pm
And also, is there a way (without temp gauge) to know if water pump is working? Like a hose I can check to see if water is circulating?I have a gauge coming...
Postby winston » Thu Jul 23, 2020 5:27 pm
Looks like this. https://www.hoyetractor.com/PROD/TS-1470.htm
Don't get burned but you can run it with the cap off. You can crank it cold with cap off and let it run until thermostat opens. At that time you will see water circulation in the radiator.
https://www.hoyetractor.com/support/kno ... article=41
GBuford4372
Postby GBuford4372 » Thu Jul 23, 2020 7:37 pm
Ah,very good. I'll try that tomorrow. Seems pretty hot to me, but I don't know
GBuford4372
Postby GBuford4372 » Fri Jul 24, 2020 11:09 am
Ok, I believe that pump is working, due to the fact that water is circulating. Problem is, I believe thermostat is open, it start circulating as soon as you start the tractor. What will be the effects of thermostat being open all time?
Postby winston » Fri Jul 24, 2020 1:35 pm
If the thermostat is open when cold it will just take it longer to warm up in hot weather and may never in cold weather.
GBuford4372
Postby GBuford4372 » Mon Jul 27, 2020 3:11 pm
Ok. I got my new thermostat installed. And now the temp doesn't get above about 135ish. That doesn't seem right to me. Now, my thermo is stuck open I believe, or it doesn't have one, which I have seen before. Any suggestions?
GBuford4372
Postby GBuford4372 » Mon Jul 27, 2020 3:39 pm
One more thing to note, temp gauge is bottomed out around 110 degrees while idling. With cap off, a thermometer is reading 145 or 150. Should there be a difference, or is the temp gauge faulty?
Postby winston » Mon Jul 27, 2020 5:43 pm
I think I would put it to work, load it, and see what your gauge shows.
Is it possible to install your thermostat more than one way?
GBuford4372
Postby GBuford4372 » Mon Jul 27, 2020 6:05 pm
I screwed the old one out, and new one in. Now, I wasn't sure about the adapter that came with it. So I tried it with and without, both seemed to be the same. the adapter seemed to just not let probe go so deep. Both screwed in the threads that were there.
Postby winston » Tue Jul 28, 2020 5:22 am
Original threads are 16 mm X 1.5.
GBuford4372
Postby GBuford4372 » Wed Jul 29, 2020 8:05 am
My suspicion was correct about gauge. Boiled water in a cup, stuck in a fish fryer thermo, and my sensor at the same time. Fryer thermo read 210ish, and my guage read around 175. 35 degrees off.
Users browsing this forum: No registered users and 32 guests
