Wrong part sent
Austinvalentine94
Wrong part sent
Postby Austinvalentine94 » Sun Jul 19, 2020 10:05 am
Good morning. I just received a radiator in the mail for a 2210 Yanmar tractor. The problem I’m having is the tractor radiator is not the right one. The inlet and outlet holes are bent at 45° angles, and the old tractor radiator are straight. There are also no mounting brackets on the new radiator. The picture on the website shows that it has the mounting brackets on the bottom, and that it has the straight inlet and outlet holes. Could you tell me whether or not this is correct? Thank you
Re: Wrong part sent
Postby Aaron » Mon Jul 20, 2020 10:44 am
The 2210 had two different possible radiators. It looks like you are already working with our parts dept so they will get you fixed up.
Users browsing this forum: Google [Bot] and 18 guests
