Power Shift Not Working
scott_hudson
Postby scott_hudson » Sat Jul 11, 2020 11:37 am
Yanmar 336D serial number 336D-41728
Symptoms: The tractor moves very slowly in all gears (both standard transmission and power shift mode).
My diagnosis so far: the hydraulic fluids are full with all cylinders extended and PTO running and 3 point up; all functions work well correctly and fast; 3 point hitch goes up and down; bucket and arms up and down without problems; the power steering works correctly. It just does not shift correctly. Tractor will creep and barely shift into power shift mode in all gear ranges.
Is there anyone who can help with this problem
Re: Power Shift Not Working
Postby Aaron » Fri Jul 17, 2020 11:12 am
Sorry I missed this post. Does your PTO work under a load- like with a mower attached?
Is your clutch pedal adjusted to roughly 3/4" of free travel?
Did it just start this or you bought it this way?
scott_hudson
Postby scott_hudson » Sat Jul 18, 2020 11:45 am
Aaron PTOis working correctly, clutch adjustmentis good,1400 hrs on the tractor,the power shift was not working well when i got it, I changed HYD oil an filters an the suction filter , it worked well for 2hrs but has slowed down now, Thank you Scott
Postby winston » Sat Jul 18, 2020 12:57 pm
Might help, might not. Trouble shooting pages out of a 226 manual. I would expect it to be very similar in the 336 manual. I read of trash or broken springs in the relief valves causing problems. Will have to add 3rd page in new post.
Postby winston » Sat Jul 18, 2020 12:58 pm
3rd page.
scott_hudson
Postby scott_hudson » Sat Jul 18, 2020 10:15 pm
Thanks Winston : Where is that spring located at? thank you SWH
Postby winston » Sun Jul 19, 2020 6:10 am
Do you have floor shift or column shift?
scott_hudson
Postby scott_hudson » Sun Jul 19, 2020 11:59 am
Winstom : Its a column shift, tha number of the spring on the schematics, the bolt torque for the floor housing, thank you SWH
Postby winston » Sun Jul 19, 2020 12:47 pm
Probably #47, could be #40.
Don't have the torque, I would use goodntight.
scott_hudson
Postby scott_hudson » Sun Jul 19, 2020 8:57 pm
winston ; thank's for the help! SWH
Postby winston » Mon Jul 20, 2020 4:13 am
Might read through this TBN thread. https://www.tractorbynet.com/forums/yan ... hlight=336
scott_hudson
Postby scott_hudson » Mon Jul 20, 2020 9:09 am
Is there sum one that knows were i can send my valve box for repare an adjustment on my 336d with powershift. thank you SWH
Postby winston » Mon Jul 20, 2020 1:38 pm
I sure don't know but would ask for more details why this has become necessary?? Or maybe I'm to nosey! Where are you located?
scott_hudson
Postby scott_hudson » Mon Jul 20, 2020 3:27 pm
I'm in western Washington, I just need to know that the valve box is working correctly ,thank you SWH
Postby winston » Mon Jul 20, 2020 4:53 pm
did you pull and inspect the relief valves?
Users browsing this forum: Google [Bot], winston and 29 guests
