2820D decompression valve sticking
Laynes69
Postby Laynes69 » Tue Jun 23, 2020 7:41 pm
When I bought my tractor I thought I was using the decompression valve when it was cold, however it wasn't working. When I disconnected the cable, the decompression valve does work but requires a tremendous amount of pull to activate it. The cable is new and free....what could be causing it to hang up?
Re: 2820D decompression valve sticking
Postby winston » Wed Jun 24, 2020 4:32 am
If all external linkage is free then it can only be the decompression shafts with the cam on it (goes through the valve cover and sealed with o-ring) are binding.
Laynes69
Postby Laynes69 » Wed Jun 24, 2020 5:43 am
Is it a difficult repair?
Postby winston » Wed Jun 24, 2020 8:06 am
Shouldn't be. A drawing of the 336, I am guessing your 2820 will be similar.
Hoping you can enlarge enough to see. About as big as this sight will allow me to attach.
Laynes69
Postby Laynes69 » Wed Jun 24, 2020 4:42 pm
Thank you.
Users browsing this forum: No registered users and 39 guests
