Ym2000 Hydraulic Issues
rbetts
Postby rbetts » Sat Jun 13, 2020 7:00 am
I’ve recently purchased a Yanmar YM2000. Perfect tractor, very pleased so far. Recently I was making adjustments to how my bushhog was being lifted (slightly unlevel) and some wheel adjustments to get rear of bushhog more ground clearance. The problem now is the hydraulics will only hold an up position. The handle slowly drops down. I’ve drained fluid , cleaned filter screen. I do not see anything visual here, where do I start?
Re: Ym2000 Hydraulic Issues
Postby winston » Sun Jun 14, 2020 5:12 am
I am not fully understanding. You say the handle (#49) slowly drops down. Notice the line of hardware that friction washer #58 is on. If all that hardware is intact you might need to tighten the double nuts (#s 60 & 61) a bit to put more resistance on the handles movement.
16-THREE POINT CONTROLS.jpg (111.05 KiB) Viewed 143 times
Users browsing this forum: No registered users and 34 guests
