Temp Gauge Issue
AllenH
Temp Gauge Issue
Postby AllenH » Fri Jun 12, 2020 7:48 pm
I installed a brand new mechanical temp gauge today in my Yanmar 2210. Ran the tractor and checked the temp of coolant with laser temp gun showing 140 deg. New temp gauge never moved off the 100 deg mark. There are no kinks in the line and everything installed easily. Is this suspect a bad unit or am I missing something? Thoughts...
Re: Temp Gauge Issue
Postby Aaron » Sat Jun 13, 2020 7:11 pm
Were were you checking the temperature with the laser thermometer?
See link below for one possibility
https://www.autometer.com/resources/ind ... view/id/11
Postby winston » Sun Jun 14, 2020 5:17 am
I am good at asking stupid questions. Did you install the new sensor and not leave the old one?
AllenH
Postby AllenH » Sun Jun 14, 2020 9:50 pm
Thanks for the responses.
lol :D yes, all brand new. On the Yanmar 2210 swapping from dummy light to an actual mechanical gauge. HTGAUGEKIT which replaces the dummy sensor. Install was quite simple and straight forward.
Gauge never moves after letting idle for some time coolant temp 140 deg at radiator and Top of the prob housing reading about the same +/- 3 deg.
Did some additional testing today. Probe/Gauge definitely bad.
I have requested a replacement gauge.
