Yanmar155d
Mjm
Yanmar155d
Postby Mjm » Wed Jun 03, 2020 4:38 pm
changing gear oil today and noticed alot of play in left wheel .is this normal if not is there a way to make and adjustment
Re: Yanmar155d
Postby Aaron » Thu Jun 04, 2020 1:34 pm
Those rear hubs use 2 bolts (#29) to clamp the hub to the hex shaped axle shaft. I would check to be sure they are tight.
Mjm
Re: Yanmar155d
Postby Mjm » Thu Jun 04, 2020 3:12 pm
I should have been more clear it's the from wheel . I did order a new woodruff key from you today ,hoping its a easy fix and that the old key sheard off
DATE: 3-Jun-2020
Web #: 166536
Order #: 359233
So far you help me with my Routine maintenance supplies
Michael McDonnell
Re: Yanmar155d
Postby winston » Thu Jun 04, 2020 5:25 pm
Unplain to an old man just where your front end play is at. Nor what key. Nice parts drawings on this sight to reference depending on your serial number. https://www.hoyetractor.com/CTGY/1554WDINT-UNDER.htm
Mjm
Re: Yanmar155d
Postby Mjm » Thu Jun 04, 2020 7:29 pm
Sorry Wiston
This old man can figure out how to attach pic or video always say file to large
Mjm
Re: Yanmar155d
Postby Mjm » Thu Jun 04, 2020 7:47 pm
The play I'm getting is in this control arm
Re: Yanmar155d
Postby winston » Fri Jun 05, 2020 4:46 am
Ok, hoping #41 is the problem.
Users browsing this forum: No registered users and 53 guests
