YM226D Hydraulic Issue
BCMaine
Postby BCMaine » Tue Jun 02, 2020 7:39 am
Have a YM226D with Powershift, Loader and Backhoe. New Hydraulic pump. loader works great till tractor warms up then loader wont move.
Pump is flowing 6gpm at required RPM. Any ideas????
Re: YM226D Hydraulic Issue
Postby Aaron » Wed Jun 03, 2020 12:35 pm
Those types of problems are usually caused by a clogged internal screen (clogs up as the tractor is running and then some of the the junk falls off when the tractor is off) or aeration. Does the oil look foamy when the hydraulics stop working? Have you replaced your spin on filter lately?
Postby winston » Wed Jun 03, 2020 1:41 pm
If it is flowing 6gpm the loader should be working. How did you measure the flow?
Postby Aaron » Wed Jun 03, 2020 1:45 pm
And when? Was that measured immediately when the loader stopped working or after the tractor had set.
Users browsing this forum: No registered users and 45 guests
