How to test alternator output
RS1301
Postby RS1301 » Tue May 26, 2020 10:02 am
Every week or so my ranch hand cannot start my 1301D - I charge the battery and it starts right up. I wonder if the alternator isn't charging the battery or is it that the guy isn't giving it enough throttle to charge? Or is it something else...
Re: How to test alternator output
Postby Aaron » Tue May 26, 2020 11:44 am
You should be seeing something over 13v at the battery when the engine is running if it is charging. 99% of the charging problems are a bad regulator
https://www.hoyetractor.com/PROD/VR-462.htm
Users browsing this forum: No registered users and 49 guests
