1401 3 point drops
Re: 1401 3 point drops
Postby winston » Sun May 31, 2020 12:41 pm
https://www.allworldmachinery.com/itemd ... FgQAvD_BwE
I can't see what 4 bolts your talking about in your pictures so can't comment on what will pull off.
dagnblond
Postby dagnblond » Sun May 31, 2020 1:06 pm
the 4 around the lock out under the front of the seat, I tried pulling the lock out itself but the piston won't come out
dagnblond
Postby dagnblond » Sun May 31, 2020 1:08 pm
Postby winston » Sun May 31, 2020 1:31 pm
Doubting there is anyway to get a hold on the piston to pull it out.
dagnblond
Postby dagnblond » Sun May 31, 2020 6:02 pm
what is this adjustment knob for
tractor lift 5.jpg (99.86 KiB) Viewed 2782 times
Postby winston » Mon Jun 01, 2020 4:08 am
I can't make out the adjustment knob, is is where I think I see a spring? Sure can't tell you what it is.
dagnblond
Postby dagnblond » Mon Jun 01, 2020 10:40 am
better pic this is on right side under the hyd line under seat
tractor lift 7.jpg (108.45 KiB) Viewed 2768 times
Postby winston » Mon Jun 01, 2020 1:40 pm
That is a new one to me. "If" that goes into the area of the control valve it might be for controlling drop speed. That is pure speculation, no fact. :mrgreen:
dagnblond
Postby dagnblond » Fri Jun 05, 2020 2:19 pm
took the controller off replaced the o-rings and think I put it together just like it came apart but when I started the tractor to test it it started and shut right back off a couple times then it started and blew the side off the controls for the FEL so I'm thinking it's building way too much pressure but not sure how that could happen
tractor control 1.jpg (61.53 KiB) Viewed 2710 times
tractor control 2.jpg (105.68 KiB) Viewed 2710 times
Postby winston » Fri Jun 05, 2020 3:56 pm
Had to be something amiss when you put it back together. Fluid is blocked there somehow.
dagnblond
Postby dagnblond » Tue Jun 30, 2020 12:23 pm
found the blockage and replaced the control for FEL but still have the 3 point dropping issue so I sent it to the tractor hospital, it was obviously beyond my abilities
dagnblond
Postby dagnblond » Fri Jul 24, 2020 4:10 pm
good news is tractor is back from the shop , 3 point works and stays up but when lowering it goes to the bottom with a bang and turning the slow drop speed knob all the way in does nothing. anything I can do to fix it or do I just need to learn to be really easy with it ?
Postby winston » Fri Jul 24, 2020 7:03 pm
Sounds to me like the tractor hospital needs to respond.
Users browsing this forum: Google [Bot] and 34 guests
